Continued fitting up HT components. Partially clecoed skin on sub structure to check hole lineup because the six holes in the rear spar bracket (T04-12) don't quite line up with rib #1 (T04-01) holes. Onex correction dtd 8/2/11 says to use the "correct aft three holes". As seen in image 2, the FORWARD three hole are clecoed with the skin installed and all holes are in alignment and the bracket contacts the aft spar. The AFT holes are off by about 1/16". If those holes were used for alignment, the bracket would need to move to the left 1/2 hole and there would be a 1/16" gap between the bracket and the aft spar.
Removed flash from holes on the forward spar strap and drilled out to #40.
